Jeg har kigget på et trådløst interface. Er der nogen der ved hvor langt signalet rækker? Der er vel en 30 meter (max) mellem fyr og min computer..
Mvh Rasms
Trådløst interface
- Stoker V
- Tilmeldt: 30 okt 2010 17:24
- Mit fyr: Scotte 10kw, Black Star
- Areal: 195
- Brændsel: 8mm træpiller
- Fremviser gerne i postnummer: 2670
- Geografisk sted: Greve, Storkøbenhavn
- Tilmeldt: 20 mar 2010 20:25
- Areal: 210
- Har takket: 29 gange
- Blevet takket: 36 gange
Trådløst interface
Nedenstående er hvad der står i min instruktionsbog for D-Link DIR-635. Bemærk specielt afsnit 2. Det gør sig gældende her hos mig. Jeg har været nødt til at trække kabel i skunk og oprette access point (ud over selve routeren) for at få dækning i hele husets 1. sal.
Wireless Installation Considerations
The D-Link wireless router lets you access your network using a wireless connection from virtually anywhere within the operating range of your wireless network. Keep in mind, however, that the number, thickness and location of walls, ceilings, or other objects that the wireless signals must pass through, may limit the range. Typical ranges vary depending on the types of materials and background RF (radio frequency) noise in your home or business. The key to maximizing wireless range is to follow these basic guidelines:
1. Keep the number of walls and ceilings between the D-Link router and other network devices to a minimum - each wall or ceiling can reduce your adapter’s range from 3-90 feet (1-30 meters.) Position your devices so that the number of walls or ceilings is minimized.
2. Be aware of the direct line between network devices. A wall that is 1.5 feet thick (.5 meters), at a
45-degree angle appears to be almost 3 feet (1 meter) thick. At a 2-degree angle it looks over 42 feet (14 meters) thick! Position devices so that the signal will travel straight through a wall or ceiling (instead of at an angle) for better reception.
3. A solid metal door or aluminum studs may have a negative effect on range. Try to position access points, wireless routers, and computers so that the signal passes through drywall or open doorways. Materials and objects such as glass, steel, metal, walls with insulation, water (fish tanks), mirrors, file cabinets, brick, and concrete will degrade your wireless signal.
4. Keep your product away (at least 3-6 feet or 1-2 meters) from electrical devices or appliances that generate RF noise.
5. If you are using 2.4GHz cordless phones or X-10 (wireless products such as ceiling fans, lights, and home security systems), your wireless connection may degrade dramatically or drop completely. Make sure your 2.4GHz phone base is as far away from your wireless devices as possible. The base transmits a signal even if the phone in not in use.
Med varm hilsen
Flemming Thomsen
Flemming Thomsen
Trådløst interface
Gå ud til din skorsten og nus lidt omkring denFlemmingth » 06 Oct 2011, 20:50 skrev:Nedenstående er hvad der står i min instruktionsbog for D-Link DIR-635. Bemærk specielt afsnit 2. Det gør sig gældende her hos mig. Jeg har været nødt til at trække kabel i skunk og oprette access point (ud over selve routeren) for at få dækning i hele husets 1. sal.
- Tilmeldt: 29 nov 2010 22:02
- Mit fyr: hkrst 10 fsk 500
- Areal: 147m2+180m2værksted
- Brændsel: flis - piller.
- Geografisk sted: kalundborg
Trådløst interface
Han er jyde, - han er vant til at slæbesnubbi » 06 Oct 2011, 21:44 skrev:levi
er du ikke lidt hård ved han, det er tungt at lave en skorsten
- Areal: 210
Trådløst interface
Jeg troede denne tråd handlede om TRÅDLØST INTERFACE.
Med varm hilsen
Flemming Thomsen
Flemming Thomsen
Trådløst interface
Det gør den ogsåFlemmingth » 06 Oct 2011, 21:51 skrev:Jeg troede denne tråd handlede om TRÅDLØST INTERFACE.
- Tilmeldt: 21 aug 2010 21:04
- Mit fyr: Black Star 30-JSH Brænder-TM3006 styring
- Areal: 183 m2 + 160 m2
- Fremviser gerne i postnummer: 4180
- Geografisk sted: Midtsjælland
Trådløst interface
Til RasmusFynbo.
Jeg bruger selv dette modem, jeg har 48 meter mellem enhederne gennem flere mure, og det virker perfekt.
http://www.a2s.pl/en/atc-863-s1-p-3783.html
Husk du skal bruge to enheder samt to antenner, ialt ca 100 Euro
EN GANG PÅ PILLER, ALTID PÅ PILLER
- Stoker V
- Areal: 195
Trådløst interface
Tak for kommentarene..
Jeg skrev også til leverandøren af softwaren, og de svarede at de nok var problematisk på den afstand, men hvis det kan lade sig gøre på 48 meters afstand gennem to mure, så burde det være fint her hos os.
