Til jer der gerne vil udnytte eller sænke røggas temperaturen på brændekedel el. brændeovn.
Pris: 1415,- kr inkl. moms + forsendelse til DK
Se dette link:
https://kotly.com.pl/produkt-turbodym-w ... .html?l=en
Weight 24.3 kg
Water capacity 17.5 l
Exhaust gas pipe diameter 200 mm
Width 316 mm
Height 560 mm
Size of the connectors:1"
Turbodym is designed to be mounted at the exhaust of the fireplace. It recover some of the energy heat contained in the flue gas leaving the combustion chamber of the fireplace insert.
It is a very economical source of heat, it does not require use of an additional amount of fuel, but uses temperature of the exhaust. Hot exhaust gases flow through Turbodym heating water exchanger shell.
Turbodym is compatible with the radiators and underfloor heating powered by solid fuel boilers, gas, oil, heat pumps and solar panels.
Turbodym is made of 4 mm thick steel. This material is suitable for use in central heating systems, provides high reliability of the device, thermal resistance and long life.
