Fejl F1 in new Scotte - whats the problem? (now solved)
petaas
Tilmeldt: 15 jan 2007 17:59
Mit fyr: Scotte/Dor
Areal: 172
Dagligt forbrug: Ca 40-45 kg.
Årligt forbrug: ca 5-6 tons
Geografisk sted: Nørhalne, 9430
Re:
Indlægaf petaas » 01 feb 2007 22:03
Good that the burner runs again.
Many have had to soldering the fotoresistor. It is a known problem.
Mvh Peter Andreasen
16 kw Scotte ver. 6,14 + Dor 16 kw
milkyway
Tilmeldt: 22 jan 2007 13:51
Mit fyr: Ikke udfyldt
Indlægaf milkyway » 02 feb 2007 19:11
petaas skrev:Good that the burner runs again.
Is there any FAQ on the internet, that describes the common problems with this kind of burner?
If not, should we make one - or is it not necessary, because of a only few problems?
petaas
Mit fyr: Scotte/Dor
Areal: 172
Indlægaf petaas » 03 feb 2007 15:40
This forum is a live FAQ, just ask - And we will answer
Mvh Peter Andreasen
milkyway
Indlægaf milkyway » 04 feb 2007 16:19
While searching for a sparepart foto-resistor i disassembled a 4 EUR nightlight from ikea (OSRAM made).
[img]http://pics.ts-audio.net/robthumb_LFH0190611.gif[/img]
there is a fotoresistor inside that has almost the same values as the one used in the scotte burner. i think with some adjustement in the scotte control box (hidden menu) it will work!
Givet likes: 34 gange
Modtaget likes: 33 gange
Indlægaf Ulrik » 04 feb 2007 16:22
Let us hear if You have succes with the project.
