16-24kw burner problems
manniste
Tilmeldt: 09 jan 2016 13:35
Re: 16-24kw burner problems
Indlæg af manniste » 13 jan 2016 22:14
Progress!
Here's me:
http://stokercloud.dk/dev/markomanniste.html
Now would really need some good settings magic :)
manniste
Indlæg af manniste » 14 jan 2016 11:35
I have a friend who has Scotte 20kw burner and when comparing our readings then my smoke temp is a lot higher.
Friend: http://stokercloud.dk/dev/semka.html?
Me: http://stokercloud.dk/dev/markomanniste.html
About the blower values. I have this blower http://www.stokerforum.dk/index.php?act ... 2620;image
according to this http://nbe.dk/wp-content/uploads/2015/0 ... fl85mm.pdf it looks like Rebeck 97, so i would need 12-18-24 but those figures just smoke a lot and don't work well.
And then I found this thread: http://www.stokerforum.dk/index.php?topic=3263.0 so according to this the condenser might be the troublemaker...
xkfc
Indlæg af xkfc » 14 jan 2016 11:48
You can not compare two different installations.
You have 300m2 while your friends just 170m2.
The location of the sensor also plays a major role, and are they both clean?
manniste
Indlæg af manniste » 14 jan 2016 12:46
Smoke sensor is new, clean and installed as manual referred.
manniste
Indlæg af manniste » 14 jan 2016 20:37
So as I beginning to understand, the blower values I kind a need to guess while looking at the flame.
But is there any settings that would help the boiler to lower the power by itself if reached its temperature. Right now it heats up and goes to Temp Stop, instead of just lowering the power. I mean is that normal and preferred? Its like takes too long for the burner to react when the temperature rises.
kivi
Tilmeldt: 09 maj 2012 22:28
Mit fyr: Black Star 1016 16 kW
Fremviser gerne i postnummer: 8300
Geografisk sted: Odder
Givet likes: 25 gange
Modtaget likes: 8 gange
Indlæg af kivi » 14 jan 2016 20:57
It should lower the power by itself, it could have something to do with PI settings, which I'm not strong on.
You could try to set the boiler temp to 65 and 15 over to prevent the Temp stop. Thats my settings.
Mvh. Ole
Givet likes: 14 gange
Modtaget likes: 75 gange
Indlæg af pille bruger » 15 jan 2016 06:46
manniste skrev:So as I beginning to understand, the blower values I kind a need to guess while looking at the flame.
From your curves, it seems as if your pump run too slowly
and that the P value is too low.
Try a higher P.
perhaps 1.5
It would be a good idea if you put the link to your StokerCloud into the signature line.
manniste
Indlæg af manniste » 15 jan 2016 12:05
Hi and thanks for help!
Increased the P and pumps speed.
When went to do that noticed that the burning crate was completely filled with pellets, to the top. ( I have this crate with the stone on top). So there was no room for anything, had to swipe some of them away just to let air move again. That doesn't seem normal also.
Indlæg af pille bruger » 15 jan 2016 13:00
manniste skrev:Hi and thanks for help!
What fan do you have ? ( i have seen the photo )
What are your fan/blower numbers ?
What are your numbers in menu Clean ?
