New and a lot of Questions
murph73
Tilmeldt: 18 nov 2011 10:42
Indlæg af murph73 » 31 okt 2012 15:37
I hope someone can help me since my Danish is really bad. new9
My name is Sean im 39 and moved with my family to denmark. In our house we have a Baxi Multiheat 2.5. The house is from 1904 with a living space of 254 m2. Top and bottum floor are heated with floor heating.
We also have a Solar system with a 1000 l puffer Tank. The stoker does not have a oxygen control. So right now im running it on hi out put until the temp is reached . Here are the specs.
Hi:
49
24
0.5
Low:
8
50
0.3
For some reason the low numbers that i wrote just dont work for a 2 step control of the stoker , even thou the Manual shows this Numbers.Can someone give me a hint to what no. i should adjust?
Also mybe where i can buy the lambda kit and a outside temp control?
Im also having abit problems adjusting the stoker to the temps outside since its not that cold yet i keep running throu the dew point?
Mange Tak
Sean
Areal: 170+60værksted+60del
Brændsel: grogodt piller
Dagligt forbrug: ca 8-40
Årligt forbrug: ca 5
Givet likes: 21 gange
Modtaget likes: 59 gange
Indlæg af thy » 31 okt 2012 16:48
murph73 » 31 Oct 2012, 15:37 skrev:I hope someone can help me since my Danish is really bad. new9
Hi:
49*********40
24********16
0.5*******0,3
Low:
8 *************8
50*********** 20
0.3***********0,1
try this all setings at once start with hi first
driftformsknap the one that looks like 1 on at dice THERE must not be ligt in that Driftformsknap then can baxi not shift HI/LO....
http://sortvvs.dk/varmesystemer-252/sto ... -3345.html
fits all baxi 1,5 2,5 4,0
Mange Tak
Sean
PS my inglish stinks :oops:
murph73
Indlæg af murph73 » 31 okt 2012 17:36
Thank You so much , i will try the settings right away! Your english is way better then my danish :)
Sean
Indlæg af thy » 31 okt 2012 17:38
murph73 » 31 Oct 2012, 17:36 skrev:Thank You so much , i will try the settings right away! Your english is way better then my danish :)
Sean
thank you :great:
were do you live in Denmark..?
murph73
Indlæg af murph73 » 31 okt 2012 18:01
I live near Sonderborg southern part.
Sean
Modtaget likes: 106 gange
Indlæg af Brandsen » 31 okt 2012 19:26
Hi there,
As just prescribed by Doctor Thy, the most important item is not to have light in 'driftsform' button,
as this will inhibit the Baxi switching automatically between high load 100% and low load 30%-100%,
and with 254m2 to heat, the Baxi 2.5 should run in low load almost all of the time.
For Baxi 2.5 the lambda kit is really convenient, as it will automatically adjust the blower to the
oxygen level needed for optimal combustion in the chamber, and hence remove the need for manual intervention
every now and then.
Also, a real 'must have' on any stoker boiler is a draft inhibitor, as this will ensure a more even
combustion, and also yield a lower pellet consumption, be preventing the nice hot smoke to be 'pulled'
out of the boiler prematurely, before it has heated the boiler body. Really good investment, cost is about dkr 600,-
Do you already have a draft inhibitor installed ?
pelle
Tilmeldt: 21 feb 2008 18:05
Brændsel: gran og fyr og sol
Givet likes: 43 gange
Modtaget likes: 42 gange
Indlæg af pelle » 31 okt 2012 22:03
Brandsen » 31 Oct 2012, 19:26 skrev:Hi there,
every now and then.
Nøøj,,, du er hård til Engelsk, Brandsen...Respekt... icon_cheesygrin.gif :great:
