manniste skrev:The draft stabilizer makes slight noise yes. Don't know about the Pascal value
Videos are helpful to compare the flame. On 100% I definitely have way too fat flame. So what should I do tho change it? The videos don't say what adjustments are needed to fix the flame.
Can you explain that part in more details: " Adjust "burner high" down until the flame get black tips, and then up again until the black tips disappear."
When you have a flame their is to fat, you need to get the blower to give more air.
What are your software number (for exsampel 6,5 or 4,8) If you dont know, turn off the power to the control. When you turn it back on, then it is written in the display.
If you for eksampel have software 6.73
You can see page 10 in the manual here:
http://sandbox.nbe.dk/wp-content/upload ... nglish.pdf
Their are a point in the menu called "blower"
Under that point, is a point called blower high. - Blower middel, and blower low.
When your burner is running 100%, and your flame is to fat. You increase the value in the setting "Blower high" until you have the correct flame.
Then you set the min and max output/power to 50%. and adjust the value in "blower middel" until the flame is correct.
At last. set the min and max power to 10% and do the same.
If you set the Draft value in the control to 0, the blower will also give more air.
Hope it make sense, otherwise ask again
