Hi guys,
Could you help me to identify my boiler model.
It is an Opop.
Measurements:
Height: 115cm
Length: 65.5cm
Width: 51cm
Picture:
http://nagi.ee/photos/arendaja/24470331/in-set/399881
My house is 300m2, and the question is that is it powerful enough for this size.
Thanks.
What OpOp model is this?
- 8
- Tilmeldt: 09 jan 2016 13:35
- 8
Re: What OpOp model is this?
Did some googleing and didn't find straight answer.
Is the boiler same for 16,24 and 30kw setups?
http://kotle.heureka.cz/opop-woody-16/specifikace/#
http://kotle.heureka.cz/opop-woody-24/specifikace/#
http://kotle.heureka.cz/opop-woody-30/specifikace/#
My concern is that did I get correct boiler from the dealer. There is no number,dataplate or anything attached to the boiler.
- J-B
- Tilmeldt: 27 feb 2012 10:28
- Areal: 85 Kvm
- Brændsel: Varga træpiller
- Årligt forbrug: 3.222,4kg.
- Har takket: 50 gange
- Blevet takket: 39 gange
I found this on NBE's homepage, http://nbe.dk/wp-content/uploads/2015/08/6.00-woody.pdf, sorry for the Danish, but on top of page 2 i says 16-30 kw.
I think your boiler is the right for your burner.
- 8
So basically for Woody burners from 16 to 30kw they used same OpOp boilers.
Good to know. Trying to rule out stuff bit by bit. I have slight trouble with my burner
I can recommend to mount the shield on the burner.
The shield prevents the risk of electrical shock and ensures that the burner temperature is measured correctly. It's for your own safety.
In the beginning NBE used the DOR boiler with four digit Scotte controller. Next step was Woody, the boiler has more insulation and the controller became more advanced, especially the auto-calculator was a great help. Later on, the first Woody controller was introduced as Scotte 6.xx series. on the OpOp boiler as a low budget set.
- 8
The red cover from the burnermanniste skrev:What do you mean with the "shield"?
- 8
A yes yes, that one is off right now just because have been messing with the burner lately, a lot. Changing capacitors and etc.
