Styring af scotte på nettet
- Tilmeldt: 14 maj 2013 21:49
- Mit fyr: Scotte mini 16kw
- Areal: 171 kvm + 90 kælder
- Fremviser gerne i postnummer: 3460
- Geografisk sted: Birkerød
- Givet likes: 1 gang
- Modtaget likes: 1 gang
Haha, ja det kaster jeg mig nok ikke ud i lige nu... Men anskaffer mig den kablede version til at begynde med
Argh, troede den kablede version krævede netværks kabel til router, men ser nu det er langt mere old School... Uhyggeligt.
Der må da være nogen som hurtigt kan udvikle noget smartere
Ellers skal jeg til at sætte mig ind i det der rasberry.dk halløj
motoz- Virker det du har linket til ? Damen syntes det kunne være en fed ting at have kørende.Skraaplan skrev:Haha, ja det kaster jeg mig nok ikke ud i lige nu... Men anskaffer mig den kablede version til at begynde med
- motoz
- Tilmeldt: 14 feb 2013 08:06
- Mit fyr: BioComfort 30kW + termax 25cr
- Geografisk sted: Ostrobothnia
- Modtaget likes: 11 gange
Hope you are okay with English (I could write in Swedish if you prefer that).
If you mean StokerKontrol on a raspberry, then it seems to work fine according to what I have read on the forums, but I get the impression that it can be a bit hard to install and set up on a raspberry.
If you mean the link to PellMon, then I am one of the authors, so of course it works . PellMon is open source, ie. it belongs to everyone, but it also means that there is no warranty. That said, I have had it running nonstop for over a year, and there are quite a few users by now that I know of. I run PellMon on a raspberry pi because of its almost negligible power consumption, but it also runs on any pc with an up to date linux version. Did you notice the PellMon demo running at http://motoz.pythonanywhere.com/?
If you have zero experience in linux, then the install instructions for PellMon could be a bit difficult to follow. I'm happy to answer any question about PellMon, and for running stokerKontrol on the raspberry I'm sure you'll get help from others.
PellMon open source pellet logger at https://github.com/motoz/PellMon
cool,
Dog har jeg lige hørt fra ham der satte mit fyr op, at der muligvis er netværks stik under styringen, så det undersøger jeg lige først
Ellers vender jeg stærkt tilbage.
- motoz
If you have one of these:
http://www.nbe-shop.dk/product/version-7-styring-541/
http://www.nbe-shop.dk/product/version- ... g-10kw-28/
then you have an ethernet port (and neither PellMon nor Stokerkontrol can be used, since they only communicate with stokercloud over internet)
The older ones, eg:
http://www.nbe-shop.dk/product/version-6-styring-26/
have an internal serial port, and no ethernet port.
The older ones, eg:
For ar se hvilken type port Jeg har i fyret skal jeg afmontere styringsboksen, korrekt?
Boksen er rød, fyret er et mini med tilhørende sort spillestil, købt i august 2013.
Er det hele boksen?
Eller kun den bagerste del?
Skal jeg løsne de 8 skruer som sidder i siden af boksen for at åbne den?
Er det hele boksen?
- Stoker X
- Tilmeldt: 17 jan 2007 14:07
- Areal: 125 bolig+200 garage
- Dagligt forbrug: 25 kg
- Årligt forbrug: 7-8 ton
- Geografisk sted: Gravlev
- Givet likes: 9 gange
- Modtaget likes: 16 gange
Hvis der er farveskærm på styringen så er det enten version 7 eller 10, hvis der touch-skærm, så er det version 10. Sort/hvid skærm fra 2013, så er det version 6.
- Tilmeldt: 15 dec 2013 10:43
- Mit fyr: Scotte BS1016 16kw
- Areal: 175
- Fremviser gerne i postnummer: 8462
- Dagligt forbrug: 20
- Årligt forbrug: 6
hej - hvis der er alm net stik (rj45) udgang på styringen?
Jeg har god nok ver 10 - men anskaffede en trådløs repeater for 300 kr. som jeg har sat op i værkstedet/fyrrummet - derfra går et alm patchkabel til styringen - og bing - det kører bare. - det eneste du skal huske på er, at den trådløse repeater skal kunne "fange" signalet fra din alm trådløse router.
Alternativt findes der på markedet net adaptere der kører via kobberet i dine stikkontakter - har dog ikke nogen erfaring for om de virker ok.
