Raspberry Pi
- motoz
- Tilmeldt: 14 feb 2013 08:06
- Mit fyr: BioComfort 30kW + termax 25cr
- Geografisk sted: Ostrobothnia
- Modtaget likes: 11 gange
Raspberry Pi
Hi Peter,
I've been busy lately so I only found time to check out your work just now. Looks very good and just works so I pulled it.
The auth.py module is copied from the cherrypy wiki, I guess that the login and logout page handlers can be moved to pellmonwebb.py (really should rename that... somehow I managed to spell web wrong..) and make a mako template out of get_loginform. By the way, I didn't really choose mako because of some preference of mine or any technical quality, but rather since I am completely new to web development I figured it was a waste of time to even try to evaluate the numerous options there seems to be so I just used the first one mentioned here http://docs.cherrypy.org/stable/proggui ... plate.html... If you wish feel free to use any other. And if you feel that cherrypy is crippling you I would be open to scrapping that also, it was a really neat way to get started for a web noob like me, but I wouldn't want you to feel forced to work with it.
Steen, what do you think about adding an optional item to the config file, eg. 'persistent-db = /path/to/persistent-db', when that's present the server copies the file pointed by it over the database at startup, and copies it back at a regular (configurable) interval, and also on shutdown. Ie. just like your scripts but easier to set up. Then the user would be free to add a ramdisk and set the database to point there and set persistent-db to a location on the sd-card. I wouldn't want it to be a requirement to know how to set up a ramdisk.
/AN
/AN
PellMon open source pellet logger at https://github.com/motoz/PellMon
- motoz
Raspberry Pi
Just pushed a version with support for rrd db in ramdisk, pretty much as described above.
- Stoker V
- Tilmeldt: 30 jan 2012 21:22
- Mit fyr: Woody 10kw
- Areal: 165
- Årligt forbrug: ~6 ton
- Geografisk sted: Sejlflod, Nordjylland
Raspberry Pi
Hi
Both MAKO and Cherrypy seems good choices to me. I have been programming PHP for some years now, so it's really just a question of learning a new language and new frameworks. Lets stick to these until there is a reason to switch
Maybe I'll have a go at moving the page handlers to pellmonwebb.py if I find the time. There are some concepts that I have a hard time understanding. Not really sure if it's Python or Cherrypy
Anyhow, I broke something:
I'm running the latest version from GitHub, and I didn't change anything on my system. Any idea what's going on?
Kode: Vælg alt
pi@raspberrypi ~/PellMon $ ./pellmonwebb.py start
Traceback (most recent call last):
File "./pellmonwebb.py", line 234, in <module>
pelletService = bus.get_object('org.pellmon.int', '/org/pellmon/int')
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 241, in get_object
follow_name_owner_changes=follow_name_owner_changes)
File "/usr/lib/python2.7/dist-packages/dbus/proxies.py", line 248, in __init__
self._named_service = conn.activate_name_owner(bus_name)
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 180, in activate_name_owner
self.start_service_by_name(bus_name)
File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 278, in start_service_by_name
'su', (bus_name, flags)))
File "/usr/lib/python2.7/dist-packages/dbus/connection.py", line 651, in call_blocking
message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.ServiceUnknown: The name org.pellmon.int was not provided by any .service files
Woody 10Kw, BS20, etc., etc.
http://peterfarsinsen.stokerlog.dk
- Tilmeldt: 26 jul 2012 21:53
Raspberry Pi
Undskyld det manglende svar på om jeg kan lave en beskrivelse af opsætning mht RRD-databasen i ramdisk.
Jeg skal få den lavet snarest
Amnd for Anders ;-)
Sorry for my late reply regarding the RRD-db in ramdisk.
I'll make a description soon
BR
Steen
Amnd for Anders ;-)
BR
Steen
- motoz
Raspberry Pi
seems as pellmonsrv isn't running, maybe it crashed. Did you try the previous version?
- motoz
Raspberry Pi
I tested it again with the git version, I can only reproduce the error by shutting off pellmonsrv myself.
Btw, it seems as autorefresh is always running regardless of the state of the button. I think it has to do with this:
if($('input[name="autorefresh"]').val() != '') {
startImageRefresh();
It runs on page load even as the button state is off. When pressing the button a new timer is created, so I think the reason is that there is now one timer running with the button off, and two timers running with the button on.
Edit: Just found this: http://view.jquerymobile.com/1.3.0/docs ... -demo.html
I think such a floating linkbar at the right would be great for navigating in the parameter view, would that be possible?
- Stoker V
- Areal: 165
Raspberry Pi
Hi
Fixed in this commit: https://github.com/peterfarsinsen/PellM ... 783322fb30
Maybe we should add an ajax handler for the autorefresh button? I only noticed it now, but since I made it a button it's not in any way clear that it's submitted by the lines form
I like the plugin you've found, but a ton of things could be done to the params page: grouping them, client side validation, hiding the 'set' button for non writable values. Etc. maybe we should start a brainstorm somewhere?
Raspberry Pi
Hi Anders.
Would it be possible to have a file written with the latest data read every time a request is received?
Such a simple file is very usefull for displaying latest values on a webpage since it's very easy to parse a simple file, instead of having to extract latest data from the rrd-databases
BR
Steen
BR
Steen
- motoz
Raspberry Pi
How about I add command line argument parsing to the client program? Then you can call eg.
in a script to get fresh readings.
Kode: Vælg alt
pellmoncli.py get boiler_temp >> file.txt
