Side 1 af 1
Vaskemaskine
: 20 mar 2014 17:17
af Falster
Gorenje vaskemaskine model wa 50149 som skriver F 1 efter vask hvad kan være fejl
Vaskemaskine
: 20 mar 2014 17:39
af Brandsen
Google er din ven :
F1 : Washing machine temperature sensor fault
The washing machine has detected a problem with the water heating temperature sensor and although the program will complete the machine will not heat the water.
Check wiring to temperature sensor or thermistor
Check thermistor or temperature sensor
Replace thermistor if faulty
Check heater
Check wiring at control module or timer
