Some PellMon news, lots of stuff have been added in the last year:
PellMon is now almost trivially easy to install on a raspberry pi: https://github.com/motoz/PellMon/wiki/H ... %20PellMon
And is much easier to configure with the web based configuration file editor pellmonconf:
Has a version number, releases and a changelog: https://github.com/motoz/PellMon/releases
Upgrading howto: https://github.com/motoz/PellMon/wiki/H ... de-PellMon
Raspberry Pi
- Stoker VI
- Tilmeldt: 16 mar 2011 21:49
- Mit fyr: Scotte m. woody chip.
- Fremviser gerne i postnummer: 4250
- Geografisk sted: Omkring 4250 Fuglebjerg
- motoz
- Tilmeldt: 14 feb 2013 08:06
- Mit fyr: BioComfort 30kW + termax 25cr
- Geografisk sted: Ostrobothnia
- Modtaget likes: 11 gange
Re: Raspberry Pi
No you won't lose a thing if you follow the upgrade instructions. But beware that the .deb package does not work on the old raspbian wheezy release, it requires the new raspbian jessie release. Unfortunately there is no official way to upgrade raspbian from wheezy to jessie (assuming you have the old wheezy release since jessie was released sometime last autumn). You can still do a manual install on wheezy if you install the missing dependency (argcomplete) with pip. A safe way to try the new version with no risk is to install on a new sd-card and then move over the database and config file, see: https://github.com/motoz/PellMon/wiki/B ... ve-PellMon
PellMon open source pellet logger at https://github.com/motoz/PellMon
- Stoker VI
Re: Raspberry Pi
Ok, thanks for the tip, i defenetly have the old wheezy version.. I hope to have some time to upgrade this week, thanks for all your great work, its so nice to have stats, and history about how the pellet burner runs
