løse træpiller northern sjælland
Tysker
Tilmeldt: 19 sep 2016 12:42
Indlæg af Tysker » 19 sep 2016 12:47
Hej everybody,
Jeg er Karsten and I don't speak Danish (but reading Danish is fine, so any advice in Danish will be appreciated). I just had an RTB 10kW pillefyr and NBE stofsilo installed, and now I need to order some pille. Unfortunately, finding high quality løse træpiller is not as easy as finding them in bags :( .
So far, I've found Ekman and Heatlets as viable options. Does anybody have any other ideas?
Brandsen
Tilmeldt: 21 okt 2009 23:02
Areal: 425 m2
Årligt forbrug: ca 10 tons
Geografisk sted: Holbæk
Givet likes: 1 gang
Modtaget likes: 109 gange
Re: løse træpiller northern sjælland
Indlæg af Brandsen » 19 sep 2016 18:42
Hi there,
I'm generally purchasing Neova pellets, Swedish quality pellets, and you can
have these in normal 16kg plastic bags, in 1 ton big bags, or just tipped.
All in 8 mm or 6 mm pellet size.
https://www.bio-dk.dk/neova-clean-pellets-lose.html
mchlbk
Stoker V
Stoker V
Tilmeldt: 12 feb 2013 23:00
Mit fyr: Pellux 100
Areal: 270 m2
Brændsel: Piller og brænde
Årligt forbrug: Ca. 6t + brænde
Geografisk sted: Odsherred
Givet likes: 17 gange
Modtaget likes: 5 gange
Indlæg af mchlbk » 19 sep 2016 20:52
Hi Karsten.
Where are you located exactly? (What is your post code?)
Tysker
Indlæg af Tysker » 19 sep 2016 21:03
mchlbk skrev:Hi Karsten.
Hi,
My postcode is 3230.
mchlbk
Stoker V
Stoker V
Mit fyr: Pellux 100
Areal: 270 m2
Indlæg af mchlbk » 20 sep 2016 15:50
Ok, East then. I'm in West, maybe some one else can help.
Why do you need loose pellets?
Tysker
Indlæg af Tysker » 20 sep 2016 19:39
mchlbk skrev:Why do you need loose pellets?
Because of this:http://pillestoker.dk/rtb-pillefyr-tilb ... udtag.html.
Currently trying to decide between the Neova pellets suggested by Brandsen (many thanks!) and the heatlets. Still hoping to find some with a water content of less than 6-8% (and in the price range of DKK 2.000/ton). If only the Fabichs I used with my old Baxi were available løst ...
Brandsen
Areal: 425 m2
Givet likes: 1 gang
Indlæg af Brandsen » 20 sep 2016 22:07
Hi there,
By 3 ton you get below your target price of kr 2.000 a ton, actually kr 1.900,
including delivery by blower truck.
But getting below 6-8% moisture cannot be done by Neova pellets, and I actually
don't recall any manufacturer issuing a product guarantee below 6-8%, but in spite
of my memory, they of course might exist. 8)
